All-Around Professional Racing Simulator
Embrace a new dimension of sim racing with the Dyn X from Cooler Master. This isn't your everyday setup; it's a rigorously designed system for passionate racing enthusiasts who relish the thrill of the track in both real and virtual worlds. The Dyn X is engineered to fuel your need for speed and revolutionize your professional simulation environment.
Racing Cockpit
PRECISION-ENGINEERED FOR A GENUINELY AUTHENTIC RACING EXPERIENCE
The Dyn X exemplifies Cooler Master's commitment to innovation, marrying form and function in a sleek package. This is more than just a gaming rig—it's a pro-level racing simulator that invites you to experience real-to-life immersion at its finest. Step into the Dyn X and feel the pulse of professional racing from the comfort of your own home.
Frame
UNRIVALED FLEXIBILITY
One single adjustment offers 14 diverse driving positions: Formula, GT, Rally, Stock Car, Off-Road, Semi Truck, and more. The Dyn X adapts to your personal simulation needs.
Seat
LONG-LASTING COMFORT
Feel Every Track Detail
With larger motors and actuators, our motion system supports more weight and delivers a powerful, torque-enhanced feel, making it ideal for commercial applications. As a highly reliable, industrial-grade system, it offers exceptionally realistic vehicle motion feedback through advanced signal processing. Experience every elevation change, vehicle movement, surface change, and gear shift with unparalleled fidelity.
Motion
PROFESSIONAL MOTION SYSTEM
Provide exceptionally realistic vehicle motion feedback.
Motion Actuators
DYN X ACTUATOR MOUNT FEATURE
Haptic Feedback
Broad Compatibility
Electronic Mounting Tray
Simple And Easy Installation
DYNAMIC ACTUATOR TRAVEL
Features 2“ (50mm) of possible travel.
RUGGED CONSTRUCTION
The actuators feature a robust machined billet aluminum housing that are built to last.
LARGE WEIGHT CAPACITY
Supports up to 800 lbs (363 kg)
Envision Conquering Your Competition
Featuring triple 34" Monitors with 1500R curve, 0.5ms response time, 165Hz refresh rate, 21/9 Wide monitor, 3440x1440 pixels
Monitor Mount
VARIO VESA ADAPTER KIT
Sound
5.1 sound System
Advanced Controls
Steering Wheel Base
STEERING REALISM, REDEFINED
The Cooler Master x Simucube 2 Pro Co-brand Direct Drive Wheelbase represents a new cutting-edge advancement in sim racing gear designed for elite racers and dedicated enthusiasts.
The Cooler Master x Simucube 2 Pro Wheelbase revolutionizes the racing simulation experience with its unparalleled precision and immersive force feedback, driven by a high-torque, brushless motor.
Engineered for excellence, this wheelbase redefines expectations, offering an unmatched level of realism and engagement in the virtual racing world.
Steering Wheel
GSI Formula Pro Elite V2
Used for attaching your steering wheel to a Simucube 2 wheelbase.
Pedal Set
HEUSINKVELD ULTIMATE+ PEDALS NO CLUTCH
A strong, durable and adjustable design capable of handling up to 140kg of actual force at the brake pedal (200kg loadcell).
Baseplate
HEUSINKVELD ULTIMATE+ BASEPLATE
If you want to mount your pedals to a baseplate first instead of mounting them individually to your rig, our Sim Pedals Ultimate+ Baseplate is your product of choice.
AMD® R7 9800X3D & NVIDIA® GeForce RTX™ 5080
PC Build in house
Pre assembled, configured and tested
Software loaded and fully configured
Asseto Corsa, ACC, Automobilista, F1 2024
SOFTWARE CONFIGURATION
Our experienced technicians will handle the entire setup process, ensuring your software is correctly installed, configured, and optimized for peak performance.
CUSTOMER SUPPORT
10 hours of online support with an expert included.
WARRANTY
We stand behind the quality of our hardware with a 1-year limited warranty. If your product experiences any defects in materials or workmanship under normal use within one year of purchase, we will repair or replace it at our discretion. This warranty does not cover damage caused by accidents, misuse, or unauthorized modifications.
OPTIONAL UPGRADES
Triple 45” OLED Curved Gaming Monitor WQHD with 240Hz Refresh Rate 0.03ms Response Time.
Purple-Glove Installation Service
DELIVERY
Premium service involving careful handling, assembly, and even removal of packaging materials.
*Contact Us for quotation, prices will depend on location and accessibility of desired location.
ASSEMBLY
Our purple-glove assembly service goes beyond standard delivery. Our skilled technicians will carefully unpack, assemble, and install your items, ensuring they're perfectly set up and ready to use.
ON-SITE TRAINING
Our on-site experts will guide you through every step of your racing simulator setup, ensuring optimal performance and a truly immersive experience.
