Powering The Next Generation With Ease
12VHPWR Adapter Cable
• 90 degree orientation
• Highly flexible cables
• Three 8-pin connectors
• 40 series GPU support
• Full PSU compatibility
40 SERIES READY, ATX 3.0 NOT REQUIRED
Highly Flexible 90-degree Cable
A 12+4pin PCIe 5.0 connector featuring a 90 degree angle to prevent unnecessary bending, and improved flexibility to enhance ease-of-use and ensure a long-lasting connection.
Up to 600W of power is split between three PCIe 8-pin connectors, providing enhanced safety.
Recommended installation
• Do not use cables that do not comply with the standard configuration.
• Do not use with additional adapter cables (e.g. 8-pin to 6+2-pin, SATA, etc.).
• Do not put the cables near any heat sources.
FULL psu compatibility
type 1
12VHPWR adapter cable
type 2
