New
360 Degrees of Cool​
MasterLiquid Core Nex Series
Dual Chamber Pump​
Innovative Design​
Flexible Pump Orientation​
Easy Installation​
Universal Socket Support​
Optimum Tubing Length
Introducing the redesigned MasterLiquid Core Nex Series from Cooler Master. Built on the trusted foundation of the MasterLiquid series, the Core Nex brings improved cooling performance with its upgraded dual chamber pump and wider CPU compatibility for flexible PC builds. With the infinity mirror pump cover design, upgraded fans, and optimized tubing for easy installation, the MasterLiquid Core Nex Series is a smart and stylish cooling solution for mainstream users looking to step up their setup.​
3 x 120mm fans
MasterLiquid Core Nex 360 Black ARGB
3 x 120mm fans
MasterLiquid Core Nex 360 White ARGB
2 x 120mm fans
MasterLiquid Core Nex 240 Black ARGB
2 x 120mm fans
MasterLiquid Core Nex 240 White ARGB
Innovative Design
An infinity mirror pump cover design brings stylish lighting and a modern touch to your build​
Featuring a rotatable pump cover that allows users to customize the orientation for the perfect look.
Dual chamber pump
Patented design
Improved Quality
Dual Chamber Pump
Our patented dual chamber design delivers a compact cooler with efficient and reliable performance.
400 mm tubing allows for effortless cooler installation in any orientation.
Easy Installation
With pre-installed fans, streamlined cabling, pre-applied thermal paste, and pre-mounted brackets, setup is quick, clean, and effortless
Broad compatibility with both Intel and AMD CPU sockets
Pre-Applied CryoFuze Thermal Paste
Tube Clips Included
